Old May 8, 2008 | 08:35 AM
Stogey's Avatar
Stogey
Default Re: steering / ignition locking
Originally Posted by DICKBEE7631
I've noticed a little "dirt"/black around the ignition key disk (the disk surrounding the key hole). Does anyone advise cleaning this disk/key hole with a shot of WD40 or other spray lubricant? Would a squirt of light lubricant in the key hole cause any trouble if the key is working fine now? Is there any way to access, quickly that pin mechanism and lub it before it becomes a problem? Thanks...
I don't think I would spray anything into the key slot. If you must, use a dry lubricant such as graphite.
Just my Dos Centavos !
