Old May 9, 2008 | 05:44 AM
imabenz's Avatar
imabenz
Default Re: 8.5 quarts of oil into an 8 quart vacuum can...
My experiance and a few others on the forum has been that you will not get all 8.5 qts out. Its been reported that just under 8 qts. get removed. I can confirm this from my first oil change.
The reason I know this is that it took exactly 8 qts of new oil to re-fill it.
With that being said, I would still be prepared for a small bit of overflow just in case.
BTW, I drained my oil from the drain plug on the oil pan and not with a top-sider. Top-sider users have reported the same thing.
Hope that helps.
Good luck....
