Originally Posted by cruzinquick
Thanks the advertisement sounds like you just charge up the bulb externally with the hose before a run. 20 seconds is not good enough for the staging lanes. It will be gone before finish your burnout. Back to the ice.
You need the 10lb tank kit to go with the intake bulb so it will run you close to $500 for 20 seconds of spray to get "ice" in the bulb lol. Not worth it at all. Also, that co2 vents out the front so as soon as you press the gas pedal it sucks it in your intake and then it starves your car for oxygen and kills your power.
the cheapest way is to get the maxcool for $35 or you can get a bag of ice.
