Thread: pulley's
Old May 13, 2008 | 09:14 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: pulley's
Originally Posted by 240M3SRT
My 185 only hits 20psi. Well it will touch 21psi for a sec or 2 when its cooler out.
Can you other guys with boost gauges confirm wether or not your seeing the max boost level raise/lower based on outside temp like i am?
I've hit 23-24 PSI - Once on the dyno, the other on a full-out run at sea level and 63 Deg F. Biggest gain over stock is when I stab the accelerator and see an instant 15-18 PSI jump from vacuum.
I see around 20PSI at redline when I shift - it think it takes the SC a few seconds at redline to build 23PSI
