Old May 14, 2008 | 05:51 AM
parawxman's Avatar
parawxman
Default Re: Rear Differential Removal
Actually, if coming up with axles is the worst problem to solve for adding a better differential to this car, it might be a good idea. The rest of the auto performance world has many outlets for custom, heavy duty, properly splined axles. But none of this has anything to do with the initial question...
Originally Posted by SRT6_Roadster
Now - where are you going to get a set of axles that are the right length and will fit the spline pattern? Does the stock drive shaft bolt up to the new diff?
