Re: NeedsWings na and srt6 CAI group buy
i am not waiting for dyno numbers i wanna be going asap, hopefully this works and doesn't throw the code again in the long run. As of now it doesn't matter if you unplug the battery or anything like that it will come back on guys its a waste of tim to keep trying things, it needs to be worked out it is something with the intake and our cars so doing that will not solve the problem. its just a temporary fix it will be back on. also if this does not work out rob and the problem comes back will there be a full refund because this is a problem there is no getting around with the engine light on. Hopefully it is all figured out and good to go but if not just making sure, because that is what i will be requesting if it doesn't work this time and the light comes back after the new parts. but also i believe i have asked before why would this only be happening with some and not all? makes me wonder because arent they all set up the same throughout the years made?
