Thread: Weird Light
Old May 19, 2008 | 05:36 AM
ZAHANMA's Avatar
ZAHANMA
Default Re: Weird Light
what that light is for is a signal for a unlocked telescoping steering wheel. if you look under the steering wheel you will see a handle. If you pull it out you can pull/push the steering wheel towards/away from you. however, when you pull this handle out that light you so comicly drew (no offense, more a compliment, if you need something done do it yourself) so i would check this handle under the steering wheel and if it is unlocked. push it away from you to lock the steering wheel if it is in fact locked and the light still comes on... check with the dealer for that was the suggestion i had.
