Old May 19, 2008 | 12:32 PM
h4auto's Avatar
h4auto
Default Re: Auto trans - Does xfire start in Second gear?
Originally Posted by MMZ_TimeLord
Again if you have the S/W switch in "W" mode (Winter) then the car will generally be in 2nd at a stop. If you have it in "S" mode (Summer), it should be in first when you are at a stop.
I'll check mine today when I leave from work and make sure this is truely the behavior on my way home.
Cheers!
thanks.
try this? Switch to "W" . From a stop hit the gas hard, does it go into FIRST? I am wondering if my switch is messed up and stuck in "W" mode(it is in "S").
aahhhwww.
