Old May 19, 2008 | 08:39 PM
  #420 (permalink)
NeedsWings's Avatar
NeedsWings
Default Re: NeedsWings na and srt6 CAI group buy
are you guys able to make a clean cut thru the 3" aluminum tubing? were going to end up cutting off the last bend on the large pipe and replace it with the new stuff connected with a black silicone coupler. i can cut them cleanly here without ruining the powdercoating with our band saw or chop saw, do you have access to one with a clean blade? it could probably be done with a hacksaw and some patience but at that point id rather send off a prepaid fedex label for you guys to mail in just the long aluminum tube and ill do it and send it back with the new end.
so we can either have you send in your long tube and ill do the swapover or i can send you the new setup and you cut the long tube. i'll provide the measurement where to make the one perpendicular cut (no crazy angles).
