are you guys able to make a clean cut through the 3" aluminum tubing? were going to end up cutting off the last bend on the large pipe and replace it with the new stuff connected with a black silicone coupler. i can cut them cleanly here without ruining the powder coating with our chop saw, do you have access to one with a clean blade? it could probably be done with a hacksaw and some patience but at that point id rather send off a prepaid fedex label for you guys to mail in just the long aluminum tube and ill do it and send it back with the new end.
so we can either have you send in your long tube and ill do the swapover or i can send you the new setup and you cut the long tube. i'll provide the measurement where to make the one perpendicular cut (no crazy angles).
Rob, I am not thrilled with doing this but if you are sure this will be the fix, I will get it cut rather than send this to you. I do not like the look of the coupling (It looks like I built it ) I want this to look finished and professional. Let me know the cuts and location. I will be painting the entire tube flat black. I would rather have all black instead of the two black couplings with silver in between. Do you have a recommendation on the paint type that will cover the powder coating ? Is it simply to prep the tube with light sanding then paint with heat resistant flat black? I will also paint the straps black to have a finished look.
I hate destroying a beautiful piece but, if you are sure, I will do. Thanks for the hard work. Can the ECU be configured without cutting this ? If so I would rather spend more than changing the look.
