Is it possible to have a complete new mandrel made with no welded sections put together?
OR ...If it is welded will the weld be visible after sandblast and powdecoating ?
I don't want to sound picky but a welded section will not look that clean either.
Time here is not a factor. Just looking for a quality looking functional product.
Your thoughts ??
there will still be one weld seam as there is with the original. we will be moving that seam a few inches towards the pass side so we can get a flush mounted maf flange. this is necessary as the 3rd bend radius is different then the first 2 hence they are bent on different machines and assembled in the welding jig.
