Operating/Usage Questions-
May 26, 2008 | 07:06 AM
17
permalink
donschorr
Feb 2008
208
Statesville NC
Re: After Warranty Visit- Operating/Usage Questions
[quote=donschorr]
I just picked my Xfire up from Lake Norman Chrysler- professionally run operation. I will determine from multiple visits as to their expertise in Xfire repairs, but so far happy with my experience.
For those who have an interest here is the response/action from the dealer to my concerns. Response/action in
RED
When it is cold- When I put the car in reverse I hear a metallic sound just a quick metallic sound- no noises while moving. Also when cold my first shift to 1st gear another metallic sound. Possible universal joints I hear?
They discovered both of my rear axle nuts were loose, they tightened the nuts and state that the noise is gone.
When cold in the morning- I occasionally smell a faint scent of antifreeze when I first start it up, I think the scent comes thru the vents.
They could not find any leaks and the coolant level is where it is supposed to be.
I will keep a look out for this still.
Do you hear the gasoline in the tank when coming to a stop- I can hear it sloshing in my tank.
They stated that the tank is behind the seats and I will hear some sloshing of the fuel.
A few times the wing deployed below 62 MPH the wing light flashes can't move it down it beeps when I try- but on restart it stays down until 62 MPH and works fine.
They discovered a fault code in the BCM for a low voltage battery, they checked the battery which is fine. They reset the BCM and it is working as designed.
I will keep a look out for this still, they told me if it trips again since they have now cleared the code, it will be easy to identify a problem if there is one.
My fan comes on occasionally, it only runs for a short period of time and turns off. My thermostat stays at the halfway mark or a little less all of the time after warm up.
They stated the fan is operating as it should be.
They looked at the transmission issue (TSB) and no leaks were found.
I also had complained about my headlights being out of adjustment- They adjusted the front right no problem. After trying to adjust the left front- they have deemed the part not working for an adjustment. They have ordered a replacement left headlight assembly.
Since this post-
I have had:
The left side head light assembly replaced, as the lights could not be aimed. The old assembly was defective.
My alarm was not operating properly, the siren was replaced.
The problem with my wing deploying- after the codes were cleared out it deployed again on its own. They have ordered a new ABS controller to hopefully take care of the problem.
So far very satisfied with dealer and the warranty program for the XFire.
Thanks
Don
donschorr
View Public Profile
Find all posts by donschorr
