Old May 28, 2008 | 08:50 AM
Playdrv4me's Avatar
Playdrv4me
Default Re: ••ü•• Angel eyes Inquiry
Originally Posted by umnitza1
First and foremost, you are comparing 2 totally unrelated products. The "7 series" forum is for 745/750 cars that have existing and pre-built angel eyes with fiber optics in them. this requires a small high powered LED bulb to power them.
Just looking at the picture you posted shows that the product is a) not the same as the one offered here - or evidenced by the photos above and b) that the products are virtually identical (and ours is $149, while their's is $300 for a little light bulb made in Korea).
If you are going to post comparisons, be accurate and not misleading.
There is nothing misleading about what I posted. Your brand name should be able to stand on it's own merits regardless of what it is that you're trying to sell. So far, it isn't doing so great on the other board so it would be pretty shitty of me to see a vendor trying to sell similar products here and ignore feedback I've seen elsewhere that might help members who don't know Umnitza from a hole in the ground at THIS board.
A simple explanation regarding the difference between the (weak) LED technology and the CCFL's you're offering here is all that was necessary to convince me the Crossfire solution might work alot better. No need to throw accusations around and get defensive. It isn't as if I'm trying to sell angel eye kits, just looking out for other board members.
My primary concern stems from the fact that the photos you show above are either taken in very low light (the first two), or appear to be enhanced (the G35 at the bottom) to improve the apparent brightness of the rings. I've seen some REALLY dim rings in the past that were not worth the glass they were made out of (CCFLs not LEDs). They may have been the thinner more easily "breakable" kind you mentioned in your first post.
