Old May 29, 2008 | 09:21 AM
brianm929's Avatar
brianm929
Default Re: Hazy Headlight Covers... wasn't moisture inside after all!
Originally Posted by rock
I called the dealer today and they told me they sell a kit with a solution to remove the hazing (including an applicator - I think it has a grit to it) as well as a protectant of some sort (including an applicator). It's expensive, naturally, since the dealer is supplying it, @ $45 a kit. Should I just buy the 3M Plastic Cleaner instead? The only thing for me is that although I have a buffer, I will most likely be applying the cleaner by hand, whatever it is that I end up using.
Rock,
I used the buffer with the Meguire's PlasticX. The buffer works great. Doing it by hand is reallllly slow.
Brian.
