Old Jul 19, 2004 | 11:27 PM
drunkiq's Avatar
drunkiq
Default Re: I heard the Crossfire was heavier than the Mercedes SLK
Originally Posted by tpulling
By somewhere around 1,000 pounds, the Crossfire is heavier and detuned according to my friendly technician. I will talk to him more, but he said that for eco-friendly emissions, the car is detuned to have less horsepower on all models.
detuned huh - the numer are close - he is probably correct - likely it is the tuned exhaust and bigger wheels we use, either way you are going to get it back after chipping... oh yeah and we are only 20lbs more than the SLK32. It is so obvious that they only did body kits on our cars...
It should not bug the AMG guys becuase next year they move to new platforms - the SLK and the AMG version look cool and have more power....
in the mean time this is how the 2004 AMG SLK compares to the SRT6:
Specifications
Type: 2004 AMG SLK32
Dimensions
Exterior
Length: 157.9 in. Width: 67.5 in.
Height: 50.4 in. Wheel Base: 94.5 in.
Curb Weight: 3220 lbs.
Front Head Room: 37.4 in. Front Shoulder Room: 51.7 in.
Front Leg Room: 42.7 in. Luggage Capacity: 9.5 cu. ft.
Maximum Cargo Capacity: 10 cu. ft. Maximum Seating: 2
Performance Data
Performance
Base Number of Cylinders: 6 Base Engine Size: 3.2 liters
Base Engine Type: V6 Horsepower: 349 hp
Max Horsepower: 6100 rpm Torque: 332 ft-lbs.
Max Torque: 4400 rpm Drive Type: RWD
Turning Circle: 32.9 ft.
Type: 2005 Chrysler Crossfire SRT6 Coupe
Dimensions
Exterior
Length: 159.8 in. Width: 69.5 in.
Height: 51.5 in. Wheel Base: 94.5 in.
Ground Clearance: 4.9 in. Curb Weight: 3240 lbs.
Front Head Room: 36.9 in. Front Hip Room: 53.3 in.
Front Shoulder Room: 52.7 in. Front Leg Room: 42.7 in.
Luggage Capacity: 7.6 cu. ft. Maximum Cargo Capacity: 8 cu. ft.
Maximum Seating: 2
Performance Data
Performance
Base Engine Type: V6 Horsepower: 330 hp
Max Horsepower: 6100 rpm Torque: 310 ft-lbs.
Max Torque: 3500 rpm Drive Type: RWD
Turning Circle: 32.2 ft.
