Old May 31, 2008 | 12:42 AM
Moparrbust's Avatar
Moparrbust
Default Re: 185mm Pulley Review
Originally Posted by MD SRT6
Spark plugs are at .039 I believe, afr fine under hard accell around 12/1. Boost unknown, In the future def needs some gauges. We will find out how effecient it is on Sunday's test and tune ( hopefully, I haven't checked the weather, but getting hot around here )
I regapped mine to .032 tonight and went to the track on a 50/50 mix of E85 and 91pump and ran a 12.61 @110.71 with a 1.91 60'..............the car peaked 17.7psi of boost on that run. It also had a near perfect AFR of 12.1 all the way up to 5500rpms again and then it slowly crept up to 14.0 AFR at redline. Definately need some tuning.
