I used this fitment tool.:
http://www.rims-n-tires.com/rt_specs.jsp
It looks like you'll have issues in front with the top balljoint nut (at 35 offset)-you'll need spacers, and they'll stick out quite a bit.
8 1/2" are the widest size rims recommended for our front end.
The rear will work OK. At 35 offset, you'll be 1/2" closer to suspension components. You might want to follow the same (22) offset as stock. If you do, the fit is identical.
