Old Jun 2, 2008 | 07:22 PM
Moparrbust's Avatar
Moparrbust
Default Re: New IC Tank Design
Originally Posted by MD SRT6
Looks awesome Brian! This is replacing the stock radiator-i/c overflow right? And if it is when you add ice how would the ice fit in if its already full of antifreeze? Is it oversized? It looks awesome and i am very interested just need more details! Thanks for the hard work and r&d. In the sweltering heat of summer those of us who like to drag race need something like this!!!
Let me first say that these are my thoughts and opinions...and not Brians.
If the tank truly separates the regular cooling system and the s/c cooling system then there shouldn't be ANY coolant in that tank(water cools better than coolant/antifreeze). Coolant is for keeping the water from freezing. On top of running 100% water in the tank, I believe, there should be a drain **** of some sort in the bottom to drain out enough water to be replaced with ice when necessary. Again all my thoughts and they may be horribly incorrect...read at your own discretion.
