Old Jun 3, 2008 | 10:38 AM
  #472 (permalink)
tylerxfire's Avatar
tylerxfire
Default Re: NeedsWings na and srt6 CAI group buy
its not going into the pipe it is going into the rubber piece that is right off the throttle body and before the pipe, i am making sure that won't change with the retrofit kit. if it won't i can mount it now. it has to be mounted after the maf sensor and before the throttle body and if it is in that rubber piece will be a direct spray into the throttle body and will be after sensor before throttle body, and easy to swap out later if i wanted to change intake or go without the spray.
