Old Jul 21, 2004 | 06:25 AM
WesMichaels's Avatar
WesMichaels
Default
Originally Posted by FerrariVdub
WMichales And BobaFettm u guys have the aut stick just like me, heres the ? I usually turn the Traction Off, but if i was to say cut the wheeel going hard into a turn or romp on the gas sometime the traction light flicks on and off and it defintly feels like the traction kicks in. DOes ures do that. Also i tried to romp on the gas to burn out and it didnt work.
Just like Boba said above.... I have seen the light flicker with the ESP off and I'm losing traction, but I've never felt the system try to take away power or control wheel speed. The only time I actually turn the ESP off is when I'm autocrossing or when I want to make sure I'm getting max performance. For normal driving I leave it on.
As far as just "romp on the gas to burn out"..... You need to turn the ESP off and torque/power brake it to about 2,200 - 2,400 rpm. Then jump off the brakes and "romp" the throttle. You'll get the rear wheels spinning. I think the Conti tires will break lose a little easier than the Michelins.
