Originally Posted by caddyman3
Ok slowly but surely modding the white base. I have seen threads about sprint booster compensating for the pedal to throttle body lag, but is it true? I have noticed quite a lag in neutral between stomping it and waiting for the engine to respond. 250 is a lot to spend on something that might not work. thanks
If you haven't tried to reset the drive by wire throttle body yet check out this thread and give it a try, it makes a difference and costs you nothing. I'm sure that the sprint booster is worth it to some but maybe the throttle reset will be satisfactory to you. Good Luck
https://www.crossfireforum.org/forum...throttle+reset
