Re: Battery dead
R.S.
There are several threads on this. Could be many things but two points to make.
1) Your windows will go up and down as part of the cycle when raising and lowering the top on your roadster.
2) I had this problem twice. Could not figure it out. Nothing left on, trunk was fully down, all the things the dealer and other XFire owners said to check.
Then I noticed that the radio would go on even with the ignition off. My Key fob or my hand was touching it after I shut off the engine. Two days later the battery was dead. I pay attention now when I shut it down. Hasn't happened since.
Not saying that is what it is but, before you spend money or time at the dealer,check it out.
The dealer most likely won't know cr*p about it either. Read the threads.
roadster with a stick
