Old Jun 7, 2008 | 09:27 PM
brain_26's Avatar
brain_26
Default Re: Harmon/Kardon Drive + Play Unit
Originally Posted by nox1s
Thanks for the huge response... but I kinda already have the unit in my car
I bought an extra unit on ebay for 30$.. took apart the lcd to make it thinner, and am going to mount it in one of my air vents or something.. IDK..
There was definitely an easier way to run your LCD cable... if you just follow the side where the fuse box is.. you can start at the bottom where the felt thing is, lift up, tuck the wire under there..and run it under the bottom across to the same spot you enter in the center console part.. but whatever works for you
How did you mount the LCD? The sticky adhesive didn't want to stick on the leathery dash, and eventually fell off
I used the adhesive circle strips that came with the unit. I have had them installed for a while, and they have not come off yet. I made sure that I used the alcohol strips, and applied pressure for about a minute or so. I guess I have to knock on wood or else.
