Originally Posted by Solarfire
I'm glad I saw your thread.....We're picking up our 06 ltd coupe on Wed and I hadn't thought about what grade gasoline to use in it. Are you saying that mid-grade is the best to use? We're in SW Fl.... very flat terrain... regular gas or high test? By the way, how large is the fuel tank?
15.9 gallons if the size is the same as a SRT & I can't see why it wouldn't be.
I'd stick w/ premium simply because that's what the car calls for. You can certainly run mid-grade but I'd drive the car like a old man then (hey, I AM an old man!). There are a whole bunch of threads about gas (including some by your's truly), I'd take the time to read through some. Many stations mix Ethanol in the lower grade gasolines, many do not do the same with premium.
