Originally Posted by chuck65
You must have meant dismount from the rims and turn to get the inner side to the outside ? Make sure that you have multi directional tires. Some tires are designed to only rotate one direction and can't be reversed.
Drat. You're right Chuck.
I've got Nitto Invo's with an asymmetrical tread pattern.
http://www.nittotire.com/#index%2Etire%2Einvo
No way to dismount and flip 'em.
I guess I've found a new maintenance cost.
Oh well, I'm still going to push it on these mountain roads; not quite the Tail of the Dragon, but there are quite a few fire breathing geckos to slay.
Do you think lowering my car to get a negative camber would be of much help?
Maybe I should go with 18's all around.
Then I can rotate, save money when I have to replace those pricey 19's and get better acceleration. Still, I'd hate to mess up the look.
