Old Jun 12, 2008 | 03:15 PM
waldig's Avatar
waldig
Talking Re: Hey waldig/ AC question
I can fix this problem tonight, just write out a check for 108$ and take your squeeze out with the money.
1! service call saved.........................
a. Go to the thermostat
b. Point at it with your finger.
c. Switch the Fan switch to ON or RUN
d. Get a rest tonight.'
What your describing is destratification of the house. The fan mixes the hot air up stairs with the other levels and the tstat corrects for the temp.
Woody AXim: The thermostat is a very inconsiderate lover, satisfies himself (herself to be PC ) and goes to sleep.
By running the lower powered fan the whole house air mass is mixed so that you dont have the momma bear baby bear and Poppa bear temperature differences of 4 -6 degrees per level.
The fan only runs a bit now with the stat and the air never is stirred, try it , like it and then write how it worked for you and your differences so that others can benefit........... The fan switch is there for your benefit use it and if your are not happy then get your bud to give back the meal weeee an easy one, Woody ENJOY>>>>>>>>>>
