Originally Posted by nox1s
If you push and hold either the lock or unlock button and look at the red transmitter, a RED LED will flash.. if the batteries are good.
I'd try replacing the batteries..as a first step..
The LED flashes once each time I push the lock or unlock button, so I guess the batteries in the key fob are good. Raised the hood checked the battery cables for corrosion, both are clean and seem to be tight.
FTroop all the electricals seem to be fine, the starter does not even attempt to turn over, no click or anything when I go to the start position with the key. I also held the brake and ran the shifter back and forth from Drive to Park several times. Nothing ! Could it be a fuse or some kind of sensor out of whack ?
