Old Jun 15, 2008 | 03:09 PM
Valk
Default Re: Washer Fluid tank -- help needed
Originally Posted by Sandgrounder
Has anyone replaced the tank? I am sure that mine has cracked or the hose has split(sloppy winter storage). I have no fluid at the nozzles and even a small amount of water will cascade from the rocker panel. I searched the data base and found a picture of the tank during the installation of Lambo doors, however the right wing had been removed! Even though its a Crossfire access to the tank must be easier than removing part of the body
So are you saying the tank will not hold any fluid or that fluid spills out when adding washer fluid to the tank ??
