Old Jun 15, 2008 | 09:41 PM
ppro's Avatar
ppro
Default Re: Possible idea to mount Drive+Play LCD?
Originally Posted by nox1s
Not really.. since it's so old I picked up another one on eBay for 30$.. not bad.
Also, I REALLY love the interface / controller of the drive+play, it's nearly identical to the iPods.. it really can't be beat..
That's quite interesting actually. Just curious - did the wire that comes out of the LCD stay attached to the guts you removed from the casing?
The trick would be that the panel you want to use is not flat and the LCD is... I wonder if the front panel of the LCD could be inlaid into the dash panel to give you the fit and finish?
I have a Karmann badge on that panel but the idea of moving my Drive + Play LCD down there sounds really good if the LCD doesn't require major fooling with to get it looking factory. I already have an extra passenger air bag panel to play with...
