Old Jun 16, 2008 | 08:39 AM
Playdrv4me's Avatar
Playdrv4me
Default Re: Water intrusion into rear central locking unit and harness...
Originally Posted by That Crazy Guy
I had a water leak in mine causing all sorts of eletrical problems. I took it in and they had to replace the wiring harness that runs through the entire vehicle. My invoice reads that there was a water leak passengers side rear tailgate area. I also remember them saying something about the right rear quater panel. I'm not a car buff, so I'm not sure if this is the same problem you are having. I also do not know much about the repair kit, but I do remember my service advisor saying he had to order the harness from MB. The entire process for them to replace the harness took over a month. I hope this is not your problem but if it is you may be experiencing erratic behaviour with your fog lights, windows, and lock/unlock switches.
Yes, we pretty much have the exact same problem however mine affects only the locking system (since the pump got wet) and apparently communications with the Instrument panel CAN connector (diagnostics).
