well, that sucks. i want one with more total gain and more %gain.
i have to really think about this, because if you have motor x with 350ft/lbs and motor y with 250ft/lbs and you take the same load/weight off each motor, i would think the weaker motor would respond better due to how much harder its working. also looking at the fact that motor y has a shorter crank so the same amount of weight removed will actually be a higher percentage of weight loss on its rotating assembly than motor x.
where am i getting confused here?
