Originally Posted by apkano
Not totally sure what your problem is.
As a informative thing only......on Crossfires, if you turn the key to start the car, and it doesn't start, you have to remove the key before you try again. This is standard, and not part of the locking system.
When you stall a manual trans car in traffic, you have to remove the key and then restart the car. (Don't ask me how I know this!
correct....well almost... you don't actually have to remove the key from the ignition you just have to compeltely turn it to the 'off' position and then you can start the car again...you have to do this when/if you stall, or if you simply turn on the accesories and then want to start the car (dumb, i know). but oh well...
