Originally Posted by Towncrier
It appears that my 2006 Crossfire is starting to experience the sticking ignition switch. When it happens, I try moving the steering wheel to make sure that there isn't any pressure on the locking pin. When I finally get the key to turn, it feels like the problem is indeed with the mechanism that actually locks the steering column and not with the switch. I haven't had anything done to correct the problem yet, but I will keep this discussion in my back pocket should the problem get worse.
When I bought mine (used) the ignition was already in bad shape. Lasted about a week before I totally went out. Tech said the ignition was really worn out because the problem had been present for some time. Since I had no warranty I was out about $750. It can be a very expensive problem if not taken care of right away.
