Originally Posted by Montana Crossfire
Just for the record I don't think a lower final gear ratio is the answer. The final already has 1st shifting very soon BUT I do think a closer ratio transmition gearing would bring great rewards.
Enjoy the Ride...
Mike
I agree. I was always told that gears are the last thing you do in the upgrade path, once you've dialed in everything else in your setup and are done with power mods. Otherwise, you have to keep re-gearing or you'll shift needlessly.
I would expect stickier tires, LSDs and other traction tricks to be exhausted before a gear change is considered.
