Old Jun 19, 2008 | 12:12 PM
  #51 (permalink)
Airscape's Avatar
Airscape
Talking Re: VRP Headers: Introductory price
Originally Posted by TVT_DESIGN
There was definately tuning involved as I know the customer was having lean issues without a proper tune.
That's the biggest issue with these results. They show gains but there are so many variables changed at once that you really don't know which was responsible for what.
I will say that you will need a tune to run headers and possibly larger injectors depending on the pulley size you have.
So assume if buying headers a tune is necessary, especially on the N/A. The SC can get away with it at lower boost.
Is 45 RWHP feasible with a tune and headers? Absolutely, if the boost is there. On a bone stock car I would expect to see more of 20-25 RWHP. Everything works in harmony, 1+1= how well we tune it.
Seeing the results still leads me to believe they are a worthwhile HP investment, although not the first thing I would do.
As far as HP/$ this rates lower then ECU tune, but much higher then cams. I guess we'll have to go get a set thrown on our N/A for some more numbers to throw around.
Thanks! I was about to say that is amazing considering the others caused a loss/no change in HP. With proper ECU tune would you say more like 330hp for the green line?
I'm just gonna think out loud here, I have an N/A so these numbers are prob gonna be way different/off but I am just thinking percentage wise. This looks like a 9-10% WHP increase on modified SRT so it would be around a 5-6% WHP increase on a similar modified N/A....TVT 250 puts you around 210WHP so I'm thinking 225ish Whp on the low side?
Would you think it is a good next step after TVT250? If so would that be packageable with an updated ECU tune to account for the headers? 2100ish lol just thinking no pressure =-)... On a side note though my 04 in VA is still bone stock and ill happily put it up for some testing if needed.
