Old Jun 20, 2008 | 07:16 PM
ChuckNorris's Avatar
ChuckNorris
Default Re: anyone familiar with tps
What was the voltage range you were getting from the wire?
Originally Posted by tylerxfire
hi guys i am trying to figure out my nitrous, i have a zex kit and just installed all the wiring, power ground power to the arming switch and the wire off the box that goes to the output voltage wire off our cars tps. so i tried the yellow wire because i got a volt reading on it that fluctuated from lower numbers to higher when at wot. it needs to be a wire like that because it will activate the box at wot and not at anything else. it has instructions to follow to program the box so i did it and it worked, then before running the nitrous and fuel lines decided to make sure it was still good but the red light was on now instead of green and now it wont program agin, power is good, ground is good, the tps wires are snug i don't get it. am i using the wrong line, i don't think so. anyone have valuable info. here. now the box is clicking when i turn the power on and flashes every time i turn it on. do i have a bad connection or wrong line please help. i am getting power from my 12v ignition wire. that runs to the arming switch, seems to have power and everything just won't program now.
