Re: just curoius about this
Its the air temp that causes the timing to be pulled as I understand it. My motor thinks the water is at normal temp but the water is only at the 172 range. The fan is running at a higher rate and the air inlet is cooler due to lower motor temps PLUS the H/E is getting MORE air due to the fan. Ill be on the track in 2 hours and well see how it all works in the real world, not bench racing theories. Enjoy, Woody
