Old Jun 21, 2008 | 04:04 AM
mikecrossfire's Avatar
mikecrossfire
Default Re: Cigarette Lighter Removal - How?
[quote=morlie822]I'd like to get to the back of the cigarette lighter to hard wire an XM radio socket. It appears that I need to get into the console from the passenger side to do this.
Can anyone provide me with a procedure to get this done? Or, if anyone has tapped into a wire near the glove box, that could work too?
wired my xm into fuse block on far left dash fuse box----run wires under hush panel at drivers side and thru the fuse block---wire to any fuse thaqt is switched to 12 volts or you can use a non switched constant 12 volt----xm radio has outo off feature----best to use switched fuse
hope this helps you
mikecrossfire
