Thread: iPod Index
Old Jun 22, 2008 | 12:42 PM
blacklimitedcoupe's Avatar
blacklimitedcoupe
Default Re: iPod Index
Originally Posted by smokey847
Is this on a non-nav unit or nav? If the latter, can one be installed on non-nav? How would you rate the sound quality of the wired FM modulator?
My car has navigation, but it doesn't make a difference. It will work on a non-nav. You just buy the little unit (I used one called TripTunes which is actually made by Ford)...then you connect a power and ground wire to the unit, and connect it between the radio and antenna using the adapter purchased from Best Buy. From here, you can connect a normal 3.5mm cable to the unit and connect the other end to the ipod. Tune your radio to 88.3 and you're done.
Mine works perfect with my ipod touch, but with my iphone it creates static because of the phone transmitter.
