Originally Posted by KrzyFast
I am working on insalling a oil catch can as well. For those that have done this mod are you replacing the TB gaskets when you remove it (same for the surge tanks if you take them off as well)? If you are replacing the gaskets, where are you getting them?
Thanks in advance!
Cheers,
KrzyFast
Im sure your supposed to replace all gaskets if you were to contact the FSM. But fwiw, i removed all the gaskets down to the heads and reused them with no leaks/issues yet.
