Old Jun 25, 2008 | 10:50 AM
Fired UP's Avatar
Fired UP
Default Re: General Tire - Exclaim UHP (Advice Needed)
On the front, you must be careful to avoid the Upper Balljoint Nut. If you stick your hand in along the top center of the tire you will feel it. Only ~ 1/2" of clearance.
I just installed
Front 235/35X19 ET 35 (Bigger Rims with no issues)
Rear 275/30X20 ET 30 (Bigger rims with no issues).
Use these as "Original" sizes and do not exceed.
Should work.
I will plug those numbers into the calculator to see the overall profile change.
Looks like Tire Rack has the Exclaim UHP's for less, including shipping, I will see if Discount Tire will price match.
Thanks Again Maxcichon....
