Re: tire fix kit with crossfire question?
The sealant is a mess. It all will need to be thoroughly cleaned from the rim and the valve stem inside before the new tire is mounted. In some cases it even ruins the valve stem as it is also the TPS (tire pressure sensor)
In the future carry a tire repair plug kit and a pair of needle nose pliers. then simply use only the air compressor to fill your tire after plugging the whole. Good Luck ,Valk
