Thread: Pedals
Old Jun 28, 2008 | 06:16 PM
rekcah's Avatar
rekcah
Default Re: Pedals
Removal
1. Disconnect the negative battery cable.
2. Remove the accelerator pedal upper nut (pic2)
3. Remove the lower accelerator nut cover and the nut (pic3)
4. Lift the accelerator pedal off of the welded stud and out of the bracket.
5. Disconnect the accelerator pedal harness connector form the accelerator pedal.
Installation
1. Connect the accelerator pedal harness connector.
2. Slide the accelerator pedal into the bracket and onto the welded stud.
3. Install the accelerator pedal lower nut. Tighten to 15N.m(11ft.lbs)
4. Install the plastic nut cover
5. Install the accelerator pedal upper net. Tighten to 15N.m(11ft.lbs)
6. Connect the negative battery cable
