Re: Regarding the rocker switch with "W" & "S" on it...
From what I have read about the "W" setting is that the shift points on the Automatic Trans. are changed (also it starts in 2nd gear as mentioned). I believe that it changes the gears sooner than if you were in "S", so as to avoid slipping the tires.
