Originally Posted by mrphotoman
The secret to big power with alcohol injection is timing advance on the engine. You can safely advance timing with the significantly lower intake temps and higher octane it provides. Without a tune and using alcohol you would see no gains.
Ok, sooooo maybe a dumba$$ question, if you tune to use alcohol and then start using straight gasoline with no alky injection then what ? Do you fry the cylinders or what
