Old Jul 5, 2008 | 12:24 PM
Jeep2Xfire's Avatar
Jeep2Xfire
Default Re: Can't get my key to turnover
I was thinking about jumping B+ tp the motor, it's just that I don't want to take the doors apart as well (Laziness) if I can do it to just the switches which are easy to get to next to the shifter, that panel just pops up.
As far as applying power to the fuses, power is already applied, the switches are what applies ground to the motors. Fuses are power side of a circuit and switches are usually ground side (Can be power side switched as well though) to protect the switches themselves. The load (window motors) will have the greatest voltage drop, and with that said; Ohm's Law applies P=IE or I2R. No voltage then it dowsn't matter how much current you're pushing, there's no power.
I'll keep looking for those wiring diagrams though. I just need to know what color wire goes to the window up. Then life will be better, not back to good, but it will be better.
Justin
