Re: Can't get my key to turnover
Dude, you missed the point of applying the power at the point of the fuse. The idea there is that the ignition switch is between the fuse and battery, not between the fuse and the window motor. Thus, by applying 12v+ to the fuse, you skip the problem that the ignition can't be turned.
Of course, after you apply power to the fuse, you still have to press the button on the center console to raise the window.
But, if you're so bent on shooting down any attempts to help you, why don't you just tape a garbage bag over the window and wait until a dealer is open on monday to fix the ignition.
