Old Jul 8, 2008 | 02:11 AM
HDDP's Avatar
HDDP
Default Re: Parts Mfg Changes '04-'05 & '06-'07 (info?)
The crank flange from the EGX manual trans is 5mm thicker than the EGZ auto trans and required a spacer. and yes the bolt patterns are different. But the important question is, what were the manufacturing changes between '05 & '06 to both the Flywheel and the Crankshaft ? did they change to a common bolt pattern ? I am assuming the current bolt pattern differences reflect manual transmission vs auto transmission attachment points. This prevents an easy bolt-up of the 6spd to the SRT6 engine without a special flywheel from a different model MB vehicle.
