Re: Power Window stopped working
The only affects of disconnecting the battery is your audio settings on the stereo will need resetting, and the clock will need resetting. The airbags will be OK. Search the forum, there's pics of doors with the inner trim panel removed. You'll be able to 90% of what you want to see - however, the remaining 10% which you can't see is the bit that's gone wrong!!!
