Re: Steering recall?
the crossfire has no supprt anymore from Chrysler. it was built by Daimler Chrysler and they no longer exhist.
If you want to find any steering TSB's check the Mercedes Slk320 2000-2003 models.
the main problem areas with the steering is the pinch bolt on the steering shaft, and the wheel bearings loosen up over time, jack up the car and check if there is play on the wheels by pushing and pulling vertically. should only have .025-.050" slop, check with dial gauge. if sloppy tight wheel bearing collar.
